Boating Logo
W
Warren mann Posted on Sep 22, 2017
Hi I have a lowrance elite 7 fish finder that won't power up ..all power cords test ok, .as it has waypoints on it is there anyway to get them? They are not on the SD card thks warren
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Feb 26, 2008
SOURCE: False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 20, 2008
SOURCE: fish finder L36HG. Also
Most likely the fish finder's clocking pulses or drive pulses are radiating to the radio.
You have to determine if the radiation is coming from the power distribution or radiating over the air to the radio's antenna.
You should get an experienced marine communications engineer to go to the boat and see exactly what is going on. He can then run some tests to determine the best plan of action to take.
Jerry G.
Anonymous
  • 214 Answers
  • Posted on Feb 11, 2009
SOURCE: brought a boat with lowrance x24 no manual with it
Here's a link where you can download the manual..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good luck & have fun. If this helps you plz rate this 'fixya' for me. Thank you kindly.
Editor925
Dean
  • 285 Answers
  • Posted on Jun 15, 2009
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Anonymous
  • 30 Answers
  • Posted on Jul 14, 2009
SOURCE: How do you get the fish to show up on the screen
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Lowrance® Elite FS 9 Fishing System Fish Finder. I have time to time restart?
Question edited for a lot more clarity. All question need FULL 'make model (what it is)'.
Question moved from 'Power Computers' to Lowrance.
Your problem is in the boat. You either have a bad electrical connection, or a bad connection TO the transducer or the transducer itself is faulty. You can return the transducer under warranty or return it for testing. It is unlikely to be the internal memory IMO.
Others report the same issue
https://www.thehulltruth.com/marine-electronics-forum/614638-lowrance-elite-7-hdi-randomly-restarts.html
Have you tried a Hard Reset.
I have a Lowrance Hook 7 fish finder and recently purchased a minn kota trolling motor with universal sonar2. Which adapter cableMKR US2-10 ? do I need.
To connect your Lowrance Hook 7 fish finder to your Minn Kota trolling motor with Universal Sonar 2, you will need the MKR-US2-10 adapter cable. This cable is specifically designed for connecting Lowrance and other fish finders to Minn Kota motors with Universal Sonar 2 technology
The diagram for the fish finder has two cables for power. does each cable have a wire going to a hot lead and a groundand a bond or do you just need to connect only one wire
Hi
One of the two cables is for power to the battery while the other supplies power to the transducer. BOTH cables (+ and -) must be used and intact.
In case anyone requires it, here is the link to the installation manual.
Hope this helps.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GB/ELITE-4_HDI_OM_EN_988-10576-001_w.pdf
2answers
Where do I get the user manual for the fish finder lowrance elite 5 ?
Go to Lowrance and you can find the owners manual on their website as a free PDF file you can download
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Top Lowrance Boating Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
