Question about Brother Sewing Machines
How do I lower my feed dogs on my Brother XL3200 sewing machine?
  • Brother Master
  • 6,034 Answers
The Brother XL3200 does not have an option to lower the feed dogs. It came with a darning plate, part number XA3443151, to cover the feed dogs. This is available at Amazon.com for less than $10, including shipping. See https://www.amazon.com/Brother-Darning-Plate-XA3443151/dp/B002EZVSUU . It's also in stock here: https://www.sewingmachinesplus.com/pd60-XA3443151.php .
The manual for the similar Brother machines, XL2600 and XL3500, show using the darning plate on page 38. This manual is available here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2600_2610_3500_3510_EN_206.PDF .
I hope this helps.
Posted on Sep 21, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
Posted on Sep 16, 2008
RickE1
Rick
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
Anonymous
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
Anonymous
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
Anonymous
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
How to lower feed dogs
Ther is a lever on the left at the back of sewing machine. Press to the right to lower the feed dogs. press to the left to bring them back up.Make sure they are in the 'up' position before sewing. My machine is a Brother 420.
Sep 19, 2017 | Sewing Machines
How do I raise the feed dogs in a Brother LS2125 sewing machine as they seem to be lowered?
Perhaps you will find the answer here:
LS 2125 2125i 2129 United States Brother Solutions Center
FWIW, the manual indicates that your feed dogs do not lower. Instead, you are provided with an accessory that covers the feed dogs when you wish to use the machine without feed dogs.
Jan 15, 2017 | Brother LS-2125 Mechanical Sewing Machine
The driver on my brother ls2125i won't move when trying to sew
If you are referring to fabric not feeding through...make sure the feed dogs were not accidentally lowered. There should be a switch/lever to raise and lower feed dogs. May have to remove extension tray/table to have access to switch. NOTE: even if switch is moved, the hand wheel will have to be rotated at least 1/4 a turn before results from switch selection becomes "active".
Nov 22, 2016 | Brother LS2125i Sewing Machine
How do I lower the feed dogs on this machine
Joyce, Some machines do not have adjustable feed dogs. Do a Google search your make and model# manual or how to lower feed dogs. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do raise or lower the feed dogs Brother
Tutorial Adjusting Feed Dog Height and Position ABC Sewing Machine
What Are Sewing Machine Feed Dogs and How Do they Work
Aug 23, 2016 | Sewing Machines
How do I lower the feed dog on a Brother LX3125?
Look on the back of the machine near the feed dogs for a lever to lower them.
If there is none then you need a feed dog cover (or darning plate) that goes over the needle plate.
good luck!
Feb 23, 2015 | Brother LX3125 Sewing Machine
How do I drop the feed dogs on my Brother sewing machine?
Altho I don't have your model, most of the Brother sewing machines have a slider kind of button on the back of the machine right in back of the needle assembly. So you push it to one side and voil? ! the feed dogs are dropped down. Don't forget to put them back up when you need them again :-)
Oct 14, 2014 | Brother Sewing Machines
Does XL5340 have drop feed dog lever?
Look on the back of the machine for a slide-type switch near the sewing area.
Aug 22, 2012 | Brother XL-5340 Mechanical Sewing Machine
Can you tell me how to lower the feed dogs on my Brother XR-52 for free motion sewing?
You use your feed dog cover, it is a plastic cover you put over your feed dogs. Your manual will show you, if you do not have your manual go to www.brother-usa.com and select support, home sewing & embroidery group, then select your manual, you can then download your manual for free
Apr 23, 2011 | Brother XL-5130 Mechanical Sewing Machine
I have brother xl3200, can i free motion sew on that?
can you drop the feed dogs on your machine ? if you can then you can
Jun 30, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
May 22, 2009 | Brother Sewing Machines
Sewing Machines Logo
276 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
