Dishwashers Logo
A
Analeen Stockigt Posted on Sep 21, 2017
We have a LG Dishwasher. The first time it worked perfectly. The second time the machine started with the cycle and the tripped the power. What is the problem?
His Example
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Sep 21, 2017
His Example
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
Helped
15426
Points
31
When in the cycle did the circuit-breaker trip? In the first few seconds, or after running successful for awhile?
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Oct 05, 2007
SOURCE: dishwasher is tripping off our safety switch
It depends on what kind of test he was doing. He was probably checking the amp draw which checks how much power the whole machine was pulling. This would be the way to check the problem you have as long as he checked it with everything running, motor, heater,..etc. If you find the amp draw to be too high, then you go to individual components.
Anonymous
  • 249 Answers
  • Posted on Feb 23, 2008
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
douglas smith
  • 1462 Answers
  • Posted on Jul 18, 2008
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Anonymous
  • 13 Answers
  • Posted on Aug 20, 2008
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Anonymous
  • 6 Answers
  • Posted on Jan 14, 2010
SOURCE: Ariston Dishwasher LI 675 DUO
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
LG dishwasher stops mid cycle
My LG dishwasher was doing the same thing. It's 2 1/2 years old. I called LG and they finally did a smart diagnostic test which showed not enough power coming in. I had to call a electrician and he checked both the circuit breaker and the line into the dishwasher and both read at 222 amps. So I called LG back and they gave me the names of three LG repairmen. All three places were over 200 miles from my home and would not come. One said that he does not like working with LG especially if it is still under warranty. But I remembered one review saying that as time goes on the door will not make a complete connection so just slam it and see if it goes. It completes a full cycle and works perfect but I have to slam the door. Hoping this works for a few more years then I will get a new one but not an LG!
1helpful
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
LG Dishwasher LD-1420T1 Tripping the main Power Board
Looks like the pump motor is drawing lot of current and tripping the circuit breaker. Need to check if there is any water inside it. Or simply the capacitor is leaky and causes motor to draw current.
See this part.
http://shop.onlineappliancespares.com.au/part/4681ea2002f-134640/43518
The dishwasher trips the safety switch in the meterbox. whirlpool ADP 5000 made in germany (not on the drop down list) the 1st time was after a finished cycle and the power was off in the morning. the...
Please DO NOT touch this machine IF the power is ON. There is a possibility of shock. The reason, the ONLY reason, that the Breaker "Trips" is, if there is a, Phase fault to Earth/Neutral, in other words the CASE of the machine. Please get a serviceman or electrician.
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 • Dishwashers
1helpful
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
1helpful
just possibly
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
