JUMP START SYSTEM Logo
B
Brett Gmeiner Posted on Sep 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My SCA starter pack is not charging, has been on 240 volt for two days
Sloop Johnb
Level 2:
Sergeant:
  • Expert 207 Answers
  • Posted on Oct 22, 2017
Sloop Johnb
Expert
Level 2:
Sergeant:
Answers
207
Questions
0
Helped
60322
Points
609
How old is the starter pack? The battery(ies) die after 3-5 years. FWIW I replaced an AGM-type battery in a starter pack and found out later it was almost as expensive as buying a new one from COSTCO or Uncle Sam's. Sounds like you're in Oz so COSTCO might not be available.
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 07, 2008
SOURCE: 21.6 VOLT RECHARGEABLE POWER PACK WON'T HOLD A CHARGE
There is nothing to do but replace it, they do wear out.
Need to charge it but my son lost the chord to charge the SCA 1900 starter were do we get the chord to the power point
Hi Richard,
The item you have is a "SCA 12V Jump Starter - 8 Cylinder, 1900 Amp" (Model PJS1900AL) which is sold by Super Cheap Auto with locations in Australia and New Zealand.
https://www.supercheapauto.com.au/p/sca-sca-12v-jump-starter---8-cylinder-1900-amp/562417.html
The Part you lost is the "240V Charger Adapter"
You need to contact Super Cheap Auto, provide them with the following information, and ask them how to get a replacement "Charger Adapter" for the Jump Starter
Item: SCA 12V Jump Starter - 8 Cylinder, 1900 Amp
Model: PJS1900AL
Part: 240V Charger Adapter
Contact info -
Super Cheap Auto
Ph (07) 3482 7500
www.supercheapauto.com.au (AUS)
www.supercheapauto.co.nz (NZ)
2answers
Have to manually reset constantly the Metz 76 MZ-5 with SCA 3202 unit.
ya you can try the Metz p76 battery pack this will overcome the problem
How do i charge rescue 950
http://www.quickcable.com/doclib/rescue950-3000manual.pdf
pg5 of the PDF above, pg 10 of the manual
Recharging
Recharge every 30 days and after each use. Failure to do so will result in possible damage to the internal battery and result in poor performance or failure to work at all.
1. Plug the AC Charging Cord supplied into the 120 Volt-in connection on the back of the Jump Pack.
2. Plug the other end of the cord into a 110/120-volt AC outlet.
3. The Red charging LED light will glow and will remain ON during the charging process When the internal battery is completely full the Green FULL CHARGE LED light on the control panel will turn on automatically. This can take up to 72 hours depending on the condition of your internal battery. You can unplug your AC Charging Cord at this time OR leave it plugged in indefinitely as the CUL™ listed internal charger is float charge equipped to maintain the internal battery
1helpful
What size power lead amp - vdc do I need for a sca 900 amp jumpstarter?
wires and cable clamps are size rated in ( awg wire) size , for example a 1/0 cable can safely handle 170 amps on 12 volts dc (car battery) , as this also happens to be the size of most all auto battery clamps and cables for most cars , I invite you to google a awg wire table for its power carrying ratings to see what size cable you need for your power pack(note look for one that's rated in 50 volts or less that's also called low voltage or class 1 )
10helpful
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
My 2005 accent will not start on its own, I need to plug a battery booster to the battery to make it start and even then it will only start if i give gas, if i do not have the battery pack on, the car just...
yes it is easy to change. but first check and make sure alternator belt is ok, and it is charging properly. with car started there should be at least 14.2-14.7 volts at battery, with accessorys off. if it is less then 14 volts at battery. then the alternator is bad. good-day !
How long do you have to charge the 12 volt battery for?
how long to charge the 12volt battery pack, using a 45va step down from 240 uk to 110 volt
Volvo 240 wont hold charge
if with the volt meter the amps go down while running and at increased rpms than your alternator is not charging right
Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Top Vector Vehicle Parts & Accessories Experts
Sean Wright
Sean Wright
john h
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
