I believe it will work without the transducer. This is based upon my locating reports of other Garmin models working without the transducer such as the Garmin echoMAP CHIRP 74sv. Garmin support would likely respond to such an inquiry.
No. St series from Raymarine are made for digital depth only, not fish finding and do not talk nmea. The only way to get that Garmin of yours to see depth would be to go from an ST40 nmea out to that garmin nmea in. Or purchase a nmea 0183 smart sensor and hook it to the garmin.
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
I would recommend having the back part of the transducer a little higher (toward the sky) than the nose of the transducer. When I say a little, I mean a very slightly. This way the nose of the transducer pushes the water and any bubbles away from the face.
It all depends on the type of boat and how you are going to be using the fishfinder. Here is my email: [email protected] if you want to discuss your uses further and if you want to purchase a transducer.
