SOURCE: I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
SOURCE: i have the the aqualux whirlpool tub, do i
The square filter on the side it tough to get off because of a rubber seal the runs around it. However, once the screw is removed there isn't anything else holding it on. You're going to feel like you're getting ready to break something, but you'll have to work with it to get it off. You might try a flat head screwdriver or a razor and carefully run it between the seal and the tub to loosen it. It will come off, it's just a little bit hard. When you remove it, you'll see why it was so hard to get off...the soapscum is all over the inside of it and some of it hardens around the seal in spots. Hope this helps.
