Please be specific
This error code indicates that the door needs to be opened and closed.
For a more thorough explanation, check out member Yadayada's explanation here -
My maytag commercial washer display code F26
SOURCE: Error Code F26
Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/RXED707.PDF although of course it doesn't list that error code and panasonic no longer support the model on their site except for the user manual. If you don't mind paying $19.50, then these guys have the service manual available which almost certainly will list the error codes and their solutions; https://www.manualsparadise.com/ShowProductsForModel.do?model=M91217722 Sorry I had no luck finding that one for free. My guess is that the lens needs cleaning, and that the error code simply means "bad disc" or something similar. Best way to clean the lens is with a cotton bud/ Q-Tip moistened (not wet) with gin - nothing else works as well or as safely. This should be easy to do as you have direct access to the lens, just be gentle. If you get no luck from that then the best i can suggest is to contact panasonic direct; http://www.panasonic.com/support/ and see if they can tell you what the code means, if they do, and you need help solving the problem, please ask again. Good luck, I hope this helps
SOURCE: i'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
SOURCE: What does error code F26 mean?
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
SOURCE: my maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.
This is most likely a problem with the door switch or a loose connection at the switch.
