See if they work else where to localize the issue between the speakers or the laptop.
Testimonial: "They work with my 3mm audio jack hard wired but my port has a bad connection on my laptop. I just recently purchased a new BT dongle because my laptop doesn't have BT capabilities so I'm pretty sure that's not it either. This is so weird!"
SOURCE: iLive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
SOURCE: HK-760 Bluetooth dongle, pairs with my HP computer
This device, according to the Jabra website, is intended only for phones, not PC's. The PC is searching for a driver in order to know how to communicate with the device. Since the VBT2050 does not have the necessary software contained within itself, the PC starts searching for device drivers. There are none that I could find on the Jabra website, so I don't think it is intended to be used with a PC.
Testimonial: "Thanks a lot for that reply, saved me a great deal."
Although I have a different model, I was having the same problem. By right clicking on the speaker icon next to the clock in the icon tray you'll get different options. Click on 'Playback Devices' and then you'll see all the speakers that are active. In my case, the default speaker was set to be my laptop speakers (you can see this because of the green dot). By simply changing the bluetooth speaker to be your default speaker (by right clicking on it) you'll hear sound again. And when the blueetooth speaker is disconnected, the laptop use your 'secondary' speakers, that is, your laptop speakers. Hope this helps!
SOURCE: CMT-BX5BT SONY spkrs aren't pulling in music (via BT) from laptop
I had the same problem. Here's the fix:
Control panel- Hardware & Sounds- Manage Audio Devices (under Sound)- Select Bluetooth Stereo Audio as default (right click- default) and Enjoy!
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
