Pebble Plus Smart Watch for Select Apple and Android Devices - Red Logo
A
Anne Walker Posted on Sep 19, 2017
Change language on GT88 Smart Watch from Spanish or some random language (Portuguese?!?) to English!! any help appreciated or watch gets returned
I have a new Carrera watch, the day is not shown in English, can it be changed?
Most watches have two dates English and another language. Pull the crown out to the first click and turn it clock wise. this may change the date, if so turn the crown anti clock wise and will change the day. It will click over to English.
I replaced the battery in my sharp watch and now it will only show the days in Spanish instead of English. How do I reset it to English?
The crown that setc the watch has two positions pull it out one position and you should be able to rotate to the proper language. One Way operates that date the opposite direction operate the day.
Good luck hope this helps
Jun 02, 2016 • Watches
35helpful
2answers
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
2helpful
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 • Watches
1helpful
I need a manual for the mtg900 in portuguese
If you go to "world.casio.com" you will see the alternative languages available. Unfortunately Portuguese is not listed.
10helpful
My citizen kinetic watch is set to show spanish days, vs. english i can see that there are english days when i change the time on my watch, but i do not know how to change the setting (this is not a...
Pull the crown out to the 2nd click...rotate the hands clockwise until the day or date changes, that will let you know that the watch is at midnight. Set the correct time, push the crown in all the way. Now pull it out to the first click and turn either direction to change the day/date to english! When your watch is correctly set then push the crown all the way back in and you are finished! :-)
10helpful
3answers
Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
Top Pebble Plus Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Pebble Plus Watch Expert? Answer questions, earn points and help others
