Computers & Internet Logo
m
mary chapma Posted on Sep 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get my jam classic wireless speaker to do anything
The indicator light is solid green but nothing happens when i try to use it with my iphone 5 via bluetooth or with a cord connetected the input jack
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 26, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140397
Points
1832
Your speaker electronics have likely failed.
A qualified technician should be able to troubleshoot the issue for you.
5 Related Answers
Brian Payton
  • 44 Answers
  • Posted on Sep 17, 2007
SOURCE: No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
justin
  • 58 Answers
  • Posted on May 01, 2008
SOURCE: Paper Jam?
add toner or image unit waste toner full check page count. check switch in duplex section same one for the fuser exit.
Anonymous
  • Posted on Jan 24, 2009
SOURCE: I cannot access my wireless network via my westell 327w Modem
the wireless light indicates activity when it is flashing thus it is probably a good sign
A FLASHING DSL LIGHT IS A BAD SIGN
it means activity getting sync which means no internet or anything
ArcAiN6
Chris May
  • 153 Answers
  • Posted on Jun 21, 2009
SOURCE: Dell Bluetooth Wireless Keyboard doesn't work
check the device for a " reset " button, they are usually located on the bottom of the device, if this does not work, you may need to contact dell directly and discuss the problem further.
Anonymous
  • 34 Answers
  • Posted on Oct 16, 2009
SOURCE: On my Zenith Plasma model #Z42PX2D, when we turn
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Why is my transmitter flashing white to blue
  • Check that the transmitter AC power adapter is fully inserted into the wall outlet and the power cord from the AC adapter is firmly connected to the transmitter power input jack.
  • If you're using the speaker power adapter, confirm that it's fully inserted into a wall outlet and the adapter power cord is firmly connected to the power input jack on the speaker.
  • If you're using batteries for the speaker, check that they are fresh and inserted with correct polarity (+, -).
  • confirm that the speaker is in 900MHz wireless mode-the indicator light on the front of the speaker should be either fl ashing or solid green. If the indicator light is blue, press the ON-OFF / RF-BT button on the back of the speaker to switch to 900MHz mode.
  • confirm that the speaker is turned on and tuned to the transmitter-the indicator light on the front of the speaker should be solid green (not blinking).
  • Check that the audio source component (stereo, MP3 player, etc.) is turned on and transmitting sound as it normally should.
  • Make sure the volume on your audio source is turned up.
  • Check that the speaker volume is turned up.
  • Make sure you have disconnected the 3.5 mm audio in cable from the AUDIO IN jack.
Is not getting charged,the red bulb remains on even after 10 hours of charging
Try a different USB cable. If you're using a 117 vac adaptor, try another one of those.
It could be the battery has gone bad. That's what happened to the one we had.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
My jam classic wont go into pairing mode at all and my phone wont pick upat all
Make sure your Bluetooth is turned on on your phone. You may have to make it discoverable as well
If U Charger The Jam 2 When It's On Low Battery In The Outlet and And The Red Light Doesn't Show What Should I do?
Doesn't sound like it's charging. Have you checked the charging pin to Mack sure it's intact. Try another micro usb charging cord too,!
How do I take apart an hmdx jam speaker?
The video shows how to disassemble hmdx jam speaker.
Soundlink 2 not charging
The power board is the likely cause of this fault and it can only be replaced by a qualified Bose Service Technician
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried...
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
1helpful
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
2answers
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Top VIA Computers & Internet Experts
Bill Eager
MegaByteMe
MegaByteMe
Aron
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
