Question about Precor Efx 576i Experience Elliptical Reconditioned
I am getting a low battery for my Precor EFX 576i. Where is the battery located, front or back and what kind of battery do i need to get?
  • Precor Master
  • 1,594 Answers
SOURCE:
  • 13 Answers
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
Posted on Aug 10, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Posted on Mar 13, 2010
bwinton
  • 83 Answers
SOURCE: I own a Precor EFX 5.33 the drive belt snapped so
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
Posted on Mar 19, 2010
dcramer531
  • 1654 Answers
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
My precor 576i cross ramp will not move
Is the battery low?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Aug 20, 2014 | Precor Efx 576i Experience Elliptical...
If I stop moving, I use to have a delay that said pedal faster. This stopped and now shuts off if I stop and I lose my stats. How do I get the delay back ?
Does the elevation work? If not, the battery is probably dead. If the elevation works fine, then it may need to be changed in the settings menu.
Apr 29, 2014 | Precor EFX 576i Experience Series...
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Replacing battery
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
Can't find the serial number -- there is no tag or it has been removed. It's a precor efx 546, MANUAL not electric and I either need a new battery or a battery charger. What do I do without the serial...
Precor Serial # Locations Type of Unit Serial # Location Treadmills Located on the label near the power cord entry and on the frame under the left rear of the treadmill. Upright Bikes Located on the front stabilizer. Recumbent Bikes Located on the front stabilizer. Ellipticals Located on the front stabilizer. Stair Climbers Located on the bottom side of one of the foot pedals. http://www.sportsmith.net/
Jan 22, 2011 | Precor EFX 546i Elliptical Version 4
Precor Efx 576i Experience Elliptical Reconditioned Logo
350 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
