Question about Hotpoint Microwave Ovens
Hotpoint mwh2322 microwave error code g80 and U1.4A?
Hotpoint microwave model RMV1435BD under recall??
None to my knowledge, but common faults include keypad failure (may show error code "F3") and cooktop light failure, both of which can be affordably repaired. (See link below)
For more free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 14, 2017 | Hotpoint Microwave Ovens
Trouble shorting
If you wish to get some details about microwave error codes; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Hotpoint Hot Point RVM1535DMWW Over the...
Model # JMV8208BAS
On a GE or Hotpoint, it usually means the keypad is defective. On some other brands, it means there's a sensor error.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 16, 2016 | Microwave Ovens
I get a SE:-0 on the controller of my hotpoint crystale mod.ks737kw-7 what should i do?
Dear Jonathan,
Here is a listing of the codes for Hotpoint Hotpoint Fault Codes AppliancePartsPros com . In your case it is a " Stuck touch Pad".
Fare. Well.
Dec 26, 2014 | Hotpoint Microwave Ovens
Keep getting error code a8 on hotpoint fdd912 dishwasher, any help would be much appreciated
If the error code is not addressed in your owner's manual then it should be addressed in the technical sheet, which will be hidden behind the back or behind the controls.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 15, 2011 | Hotpoint Microwave Ovens
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
Microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
