Okay, go to your manufacteres website, (if your pc is dell then go to DELL.COM)
then in the website of your manufacturer go to the drivers download tab, or support by product, and input the serial number of your machine, once you have, you will see a list of the drivers that are the latest, just go to the bios tab, and download the latest update you need..
NOTE: some pcs wont let you jump bios versions, for example if you were to have version 4 and the latest is 9 then the bios update will not work, and you will havee to install all of them in order to get the latest one.
i hope i helped you!
Testimonial: "Lenovo does not offer any further updates for the original IBM machines any longer. so unless someone has a bios update down load for this 8189UNU M50 desktop they have saved back along. the lat and latest update is the july 6 2005 that is in it now. thank you for the thumbs up anyway ! Bill !"
SOURCE: Can Windows 7 be installed on X05? I get ACPI
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram.
I run windows 7 on 2GB and its great, your machine will take 2GB.
The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine.
i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
BELOW YOUR MACHINE SPEC
Key Features
Laptop Type Thin and Light Laptop
Use Corporate Business • Small Business • Business
Processor Pentium M 1.5 GHz
Installed Memory 256 MB (DDR SDRAM)
Display 14.1 in. XGA TFT LCD
Operating System Microsoft Windows XP Professional
Mobile Technology Intel Centrino Mobile Technology
Processor
Processor Manufacturer Intel
Processor Type Pentium M
Processor Speed 1.5 GHz
Motherboard
Chipset Intel 855GM
Bus Speed 400 MHz
Memory
Installed RAM 256 MB
RAM Technology DDR SDRAM
Max Supported RAM 2 GB
RAM Speed 333 MHz
Installed Cache Memory 2048 KB
Hard Drive
Hard Drive Capacity 30 GB
Storage Controller Type Ultra ATA 100
CD / DVD
CD / DVD Type CD-RW/DVD-ROM
Optical Drive Read Speed 24x (CD) • 8x (DVD)
Optical Drive Write Speed 8x (CD)
Optical Drive ReWrite Speed 8x (CD-RW)
Display
Display Tech XGA TFT LCD
Screen Size 14.1 in.
Display Max. Resolution 1024 x 768
Video
Graphic Processor NVIDIA GeForce4 440 Go
Graphic Bus Interface AGP x4
External Video Resolution 1920 x 1200
Audio
Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
Audio Input Type Microphone
Operating System
Platform PC
Technical Features
Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
Input Method Keyboard • Scroll Button • Touchpad
Networking
Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
Modem
Modem Type Fax / Modem
Analog Modulation Protocol ITU V.90
Battery
Battery Run Time 2.2 Hours
Battery Technology Lithium ion
Dimensions
Width 31.5 cm
Depth 25.9 cm
Height 2.4 cm
Weight 2 kg
SOURCE: I need bios or bios update installer.. motherboard
http://www.msi.com/product/mb/PM8M-V.html#?div=BIOS
Testimonial: "thx.."
SOURCE: I have a DELL Inspiron 1720 with windos vista. I
You need to check the specifications of your laptop it may not be able to run Windows 7. 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit) 16 GB available hard disk space (32-bit) or 20 GB (64-bit) DirectX 9 graphics device with WDDM 1.0 or higher driver
You need these specs:
SOURCE: Hi I'm looking for LG Rocky Motherboard bios update for my LG P1-J2HHV3. I want to install Windows 8
Why would you require a BIOS update? It does not factor with an OS change. Instead concentrate on drivers being supported by Win 8.
Upgrading
BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many
manufactures have a disclaimer. "You are on you own, and the likes for a
reason. Most solutions are found elsewhere.
However,
if you truly need to update read this to help you with the upgrade. You don't want to end up with a brick.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
