SOURCE: IBM Mainboard MS6188 on Net Vista IBM PC Systemes ??
Your machine is a Netvista 6280 or similar. Several models used that MSI motherboard. Go to http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4RZ2LT
IBM's latest BIOS and all other 6280 drivers are listed.
The MS6188 motherboard uses an Intel 810 chipset, you should not have any drive size problems, at least up to 30 GB, that could not be overcome by partioning the drive.
Good luck.
SOURCE: ibm motherboard pro300a_afp bios update
Go to the Bios's Manufacturer's website, they will have it, get the update, and instructions to update.
there is a Specific procedure to follow.
Hope this helps
Regards.
SOURCE: bios update for t5226
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
SOURCE: ibm 8434 -rya bios updation software
http://free.windows9download.net/download/ibm-thinkcentre-8434-mother-boad-drivers.html http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
before you think about updating the bios you should look to updating the drivers and check for malware and bugs
http://free.windows9download.net/download/ibm-thinkcentre-8434-update-bios.html
hope this helps
hope this helps
