Hello!
According to the manual (included in the link), there is no way to change the password on the Precore 9.35 Treadmill from its default setting.
If you would like to disable the password, follow these steps:
1. At the Precor banner screen, press STOP, SPEED?, SPEED?, ENTER, PROGRAMS very quickly
2. At the SELECT UNITS screen, press ENTER
3. Using the arrow keys, select DISABLED at the PASSWORD prompt
4. Press ENTER to accept these settings
https://www.precor.com/sites/precor.com/files/manuals/48854-103%2520933i_9.35i%2520Lit%2520Kit_1005_EN.pdf
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: How to change to KM
The detailed procedure to change the measuring standards on a Precor C944 treadmill is given in the service manual.
To download and print the service manual in PDF format, click this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
The detailed steps to change the measurement standards are given on pages 9 and 10.
Hope this helps. Thanks for using FixYa.
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
