The chain keeps coming off in during use. I can't seem to adjust the tension.
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
SOURCE: i can't seem to find a replacement chain for the pole saw
The replacement part number is a 10SC. You can contact Master Parts to order one. You can find them online at www.masterparts.net or you can call them toll free at 800-446-1446. I hope this helps...
SOURCE: ZX6 Noisy Cam Chain
if your chain is makeing nois it would be a good idear to replace the chain a manual cam chain tenshioner will take the slack up but what about the valve timeing a worn chain will throw it out due to the chain stretching plus the manual tenshioner will make the guides wear faster if ya auto matic tenshioner has reached its limit that means replace chain no ifs or buts
SOURCE: chain fell off chain saw remington 10
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
SOURCE: Chain keeps falling off bar afterwhen saw is
Reinstall the chain. Do NOT connect power. Mark one link (chalk, crayon, etc.) wear gloves and try to rotate the chain one complete revolution. Is this possible? No - remove the chain and remove burrs from the sides of the drive links with a flat file.
An IPL for your saw can be found here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter "111409" in the "Search for your unit by Model #:" window. Click search. Click "View Model" Click "View Illustrated Parts Diagram"
Yes - inspect the sprocket gear (KEY NO. - 11) pn 111363-01 new pn 122520-01 NLA, is it deeply grooved or perhaps worn through?
I'm going to get smacked as I have so many times before. The only thing RemingtonPower is producing today is unhappy customers. Replacement parts are exhausted. we aren't affiliated and had nothing to do with their decision to stop production.
Burrs on the chain or a defective sprocket are the most likely causes of your problem. If the gear is bad, there are no replacement parts available and I cannot help you further except to recommend you purchase a name brand replacement. Select a company you think will have replacement parts when you need them sometime in the future.
Chain adjustment
Your rating of our help is the only payment we get for this service. I provided as much help as humanly possible. Punishing me for your disappointment with RemingtonPower isn't fair to me. I hope I answered your question. Thanks. A few kind words would be appreciated.
Lou
