Home Security Logo
t
tommy barker Posted on Sep 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Nitin Khatri
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 97 Answers
  • Posted on Sep 27, 2017
Nitin Khatri
Expert
Level 2:
Mentor:
Answers
97
Questions
0
Helped
87000
Points
564
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
2 Related Answers
Anonymous
  • Posted on Jul 22, 2012
SOURCE: Samsung sde 3004n works but can't get to menu up
Same issue here!! Grr
mobil master
Computer Repairing
  • 14641 Answers
  • Posted on Oct 31, 2012
SOURCE: need to reset password on my samsung sde-3004n
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I have a samsung DVR model SDE-4001N. And I forgot the username/Login ID and password. I have no remote. How do I rest it.
  • Turn the device Off. Wait 2 minutes. ...
  • The unit should power on. Once it does, you can release power.
  • Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  • Activate the reset using the HOME button.
Samsung Security DVR Google Search
1helpful
Forgotfactorypassword can i reset
hard reset code type to your home screen
hard reset for samsung *2767*3855# wait the automatic restart then finish 1st step you can do is? go to setting get started to set any thing you want thats all
2answers
How can I reset My Samsung sde-5003n back to defaults?
Suggest using Google to access a copy of the manual. Some units have a reset function, other are like a computer with an internal battery or reset button.
How do i reset my user name i cant remember it
If you want to reset your username then go to settings -account and open your account settings. Here you can delete the previous account and make a new one. Enjoy
Need to reset password on my samsung sde-3004n
Top Samsung Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
