SOURCE: need code to pair my technocel bluetooth
If you haven't found it yet, use 0000. If this is helpful, please post as such. If it fixed it please post as fixya
SOURCE: I need the instruction manual for PS3 wireless controller
push the select and L3 buttons at the same time after you push the connect button on the little mechanism, it should flash fast then press the home button to register it., make sure you follow the directions exactly. console must be off and the mechanism must be plugged in to port 1, turn on click the connect button then L3 and select at the same time then home button. the thing is garbage though the control are unresponsive. Took forever before i could get it to register.
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
