SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
SOURCE: Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
SOURCE: MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
SOURCE: how to install 3 1/4 planer blades into makita
go to Makitausa.com and download an owners manual and it will have directions on how to do this. Let me know if you still have problems.
SOURCE: I need instructions on how to replace a new set of
find your model number and go to "makitause.com" and you can download the operators manual with detailed instructions for this repair. REMEMBER to unplug tool before starting. If you give me the model number I will help but they had 2 different types of holders on the planers so I can't begin to help. Let me know.
