SOURCE: MIELE G7859 DISHWASHER FAULT CODE
Hi .....F26 means the flood switch within the base has been activated ..........ya need to rmove base and raise of the floor and test on cycle looking for a water leak.
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday:
8:00 am - 8:00 pm EST
Saturday-Sunday:
Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
SOURCE: bosch exxcel 1200 express fault code f04 what is
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
SOURCE: on my miele dishwasher G1220
Hi.
The slide shutter is part of the circulation pump assembly. Disconnect pump and check for blockage at pump hose. If that does not help replace the circulation pump.
Regards.
Ginko.
