SOURCE: Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
SOURCE: Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
SOURCE: Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
SOURCE: Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
