Brother DCP-7020 Black and White Copier Logo
Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toner life end warning light. replaced with new toner/drum still error
Anonymous
Level 2:
  • Expert 105 Answers
  • Posted on Aug 04, 2009
Anonymous
Expert
Level 2:
Answers
105
Questions
Helped
42793
Points
235
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
6helpful
2answers
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
9helpful
I just installed a new drum and toner cartrideg last week and the error message says drum is near end. Should the toner cartride be replaced?
After replacing the drum and toner you may need to reset the drum life of the machine. This is how to reset the drum life:
Open the front cover where the drum and toner are located. Press the clear/back key. Lcd should show Replace Drum? Then press 1 for yes. Lcd should show accepted. Close the front cover the press stop/exit. Lcd now should show the date and time.
Hope this helps. Rate if it works. Thanks
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
17helpful
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Toner life end.
-open front cover
-press 'Option' button
-then key *00 on the keypad
-This resets the device so it knows it has had a new cartridge.
I hope it helps
65helpful
4answers
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
1helpful
3answers
1700 Drum Error
hold cancel button down with door open, this should rest it
Norman Weimar
Norman Weimar
k24674
