Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
it has lamp which has 2000hour in normal and 3000 in econom mode to shinenormal then it must be changed and your may already in this state and began such things.
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
I think due to Battery your laptop should not be slow . But as per the RAM in your laptop you need to add some more RAM with WinXP and SP3 with the type of Configuration it will be slow with or without power.
