SOURCE: Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
SOURCE: Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
SOURCE: I own a Whirlpool Dehumidifer
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Testimonial: "I really appreciate the tips, will try them this evening."
SOURCE: We have a Frigidaire 70
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
SOURCE: Do I have to do something, not mentioned in the
This is usually cased by either a clogged drain hose ro the hose connection and tubing on the unit is clogged. When this happens, water is diverted into the bucket.
First, turn the unit OFF & unplug it.
To unclog the connection and it's interior tubing. Disconnect the hose and using an 18" long plastic Zip Tie appropriately sized Zip Tie, carefully insert the tip into the hose connection and the tubing. Slowly push it in unitl you reach a bend in the tubing. You will need to gingerly work is past this bend, until the Zip Tip bottoms out or you run out of usable Zip Tie. Then slowly pull it out while rotation (twisting) it. This should breakup any clogs. As you reach the tip of the inserted Zip Tie, be prepared as some water may follow. Reconnect the hose to the connection, plug the unit back in, turn it On and lower the humidity extraction level to 35%. Monitor the hose periodically for water flow.
Be sure the hose slopes down and away from the unit and is not longer than 5 feet. As drainage relies entirely on gravity to drain.
NOTE: You may substitute something similar to a plastic Zip Tie. But, no wire coat hangers.
Hope this helped you and thanks for choosing FixYa.
