Question about Yes Televison & Video
Se42umt 42cdm3b535sa02379 will not turn on,, yes i checked cord
Red light is on but nobody home when turned on by remote or manual setting
SOURCE:
  • 36 Answers
SOURCE: will not turn on...just a flashing red light
Evidently this is a common problem with Toshiba rear projection TVs. You might be able to get it working temporarily by unplugging it, pushing the power button a few times, plugging it back in, and then turning it on. Most likely your power supply is going out on you, and should be taken in to be repaired.
Temporary solution found here.
Posted on Aug 02, 2009
  • 277 Answers
SOURCE: The TV will not turn on either with remote or
your power supply is blown
Posted on Jan 19, 2010
toolkits
  • 1099 Answers
SOURCE: tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
Posted on May 23, 2010
budmrtn
  • 11361 Answers
SOURCE: The TV will not turn on. No power light
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Posted on Jun 22, 2010
  • 11800 Answers
SOURCE: EMPREX Mod HD 3201.
This is what happens when the power source of the tv detects a big short on one of its outputs - it goes in emergency shutdown. The only way to fix that is to open the tv and test the power source to identify the shorted output. After that you must test every single component that output powers to find and replace the failed one.
You need at least a basic understanding on how a tv and each component works. If you don't know that then there's nothing you can do, call a repairman.
Posted on Oct 29, 2010
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
How do I fix my Konka led TV?
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 05, 2016 | Televison & Video
Lost remote audio speaker need to turn bass off how
Without more information it's difficult to answer your question accurately.
Try a universal remote which has been set up to work with your audio system.
Or, read the manual and find out how to access the bass controls on the front panel. I know nobody likes reading manuals, but sometimes they tell you what you need to know - you just might have to dig in and find it.
Jul 04, 2014 | Audio Players & Recorders
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
My name is shakena brown, i have a sanyo 32in flatscreen TV that I brought from Wal-Mart. The TV is not an year old yet and it will not show anything. When I plugin the cord in and turn the TV on the...
Your set is still under a manufacturer warranty. Take your set back to Wal-Mart and they will send it out to be repaired, or give you a new one.
May 19, 2011 | Sanyo Televison & Video
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
When trying to set up my new SRP2008B remote should the TV be on or in standby mode? In step 2 should the red LED be flashing or stationary? The Quick start guide is somewhat ambigious about these two...
U are setting up a universal remote?Yes,tv should be on,second push the search button on the remote,should be flashing and enter all those codes provided by the manual one by one the LED light of the remote should be solid red as the codes enter one by one the red light and go off and pushing the on/ff button on the universal remote for each codes as u got the wright codes the tv will turn itself off.
Apr 11, 2011 | Philips Televison & Video
Jun 22, 2010 | Protron PLTV3250 32 in. LCD Television
Can I use the Smart Remote 15-2104 for a Cyberhome DVD Recorder?
The product manual doesn't list the Cyber home product. You might want to try a code scan, that might turn up a code set that is close. Here are the instructions:
USING MANUAL CODE SEARCH
If your home entertainment device does not respond
to remote control commands after trying all of the
codes listed for your brand, or if your brand is not list-
ed, try searching for your code.
Follow these steps to search for codes manually.
1. Turn on the desired device.
2. On the 6-In-One Remote, press the appropriate
device key once.
3. Hold down P until the red light blinks twice.
4. Press 9 9 1. The red light blinks twice.
5. Aim the 6-In-One Remote at the desired device
and slowly alternate between pressing POWER
and the appropriate device key. Stop when the
device turns off — a working code has been
found.
Note: In the search mode, the remote sends IR
codes from its extensive library to the selected
device, starting with the most popular codes.
Because of the library’s size, this procedure may
take some time. When the red light blinks three
times, the search of every code is complete.
6. Press P once to lock in the code.
Mar 20, 2008 | Radio Shack 15-2104 Remote Control
Magnavox 20MF251W won't turn on at all
my tv is not rurnine on the standby light is on
Aug 27, 2007 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
Televison & Video Logo
37 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
