SOURCE: Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
SOURCE: stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
SOURCE: sanyo plc xu 40 lcd projector problem
hi i have a infocus lp720 with new lamp but there red and green images all around the outside of things what is it and can this be fixed cheaply? thanks john
SOURCE: Ipod Nano stuck in locked mode
well plug your i pod into itunes and reset your i pod to factory default
Trust me I had the same problem
SOURCE: Sanyo PLV-70 Projector
check the safety switch under the lamp cover if the has snapped there wont be any power
[2] Insert a thin SLIDE into the GATE MECHANISM; the DARK SHUTTER should open.
Hope this helps you and you have the slide projector working again soon.
Regards,
Michael
Adjusting the DARK SHUTTER
[1] Do the removal for the LOWER HOUSING.
[3] Check the the PRESSURE PAD is correctly aligned with the the DARK SHUTTER.
[4] Bend the PRESSURE PAD to adjust the alignment.
This is from page 34 of the SERVICE MANUAL, which you can view in its entirety here:
http://slideprojector.kodak.com/plugins/acrobat/carousel_sm.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
