How to fix nexus 6p when it won't start, won't charge, dasnt blink and pc dasnt pick it up. Have tried all the variations. With holding down the side buttons wile it plugged in to the wall outlet with original cable. With USB original cable, with out being plugged in, being plugged in for a wile than unplugged and plugged back in with in 10-15 sec still nothing !!!!
SOURCE: nexus tv
That is normally an issue with the control board. You can contact Nexus Support at 800-642-3087 ext 235 and they can take care of getting you a new one.
SOURCE: will not start on battery or plug-in to wall
Take out the hard drive and dvd drive and also make sure the battery is out. Plug in the AC Adapter and then see if the laptop turns on. If it still doesn't turn on then that means the motherboard is bad.
SOURCE: My samsung galaxy nexus doesn't always charge when
please book your complaint to service center
SOURCE: My bluetooth does not recognize my new phone
It you have bluetooth correctly activated, try with the bloetooth of someone else to test your phone. I can't imagine what else you can do. If won't woork, probably your phone's bloetooth is defective. Happens.
If on watrranty, ask them to repair it.
I had this problem with a cellphone I had, never could sync it.
