SOURCE: rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
SOURCE: The ovens in the rangemaster
Try putting your grill on low for 30 minutes to one hour the clock should start to flash then leave to flash for five minutes after which press reset. It worked for me on my rangemaster 110 (gas)
SOURCE: rangemaster 110 clock stuck on auto so oven wont work
same happened to mine and had to get new clock
