SOURCE: Life fitness recumbent bike problem
Hi
We had exactly the same thing. If you take the covers off you will find a black battery pack in the bottom. It is about the same size as a cordless drill battery. We got a replacement from Maplins - cost about £10. It works perfectly now.
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
SOURCE: i have a life fitness
Usually a faulty lower circuit board - remove and replace or call a local service tech.
follow this link for the instruction manual and the makers website
http://www.diamondbackfitness.com/media/pdffiles/catalogs/manuals/1100/1100_R_OwnersManual.pdf
