Pakistan vs world xi match played at Qaddafi Stadium Lahore, on which channel see the match live
SOURCE: service codes
It is not service codes that you need. The set is not matched to the broadcast standard where you are located.
Many of the flat panel TV models work with a PC interface for the factory setup. If any parameters have changed with the age of the set, the fault is failing components, and not adjustments to be done. Over-compensating for a fault is not a fix.
As for your TV set, if I recall correctly, the factory service setup is done through an interface to a PC with the service software. The interface on some sets works with the HDMI cable, a USB type connector, or a serial connector, or the back cover has to be removed and there is an interface connector on the processor board.
Jerry G.
SOURCE: Display problem
Lahore (042)
Appliances & TV Service Center
LG-Plaza, 11-A, Lawrence Road, Lahore
Tel: +042-7210273, 7242611-089
Send an E-mail.
Mr. Saadi (TV/PDP/LCD TV)
[email protected]
Mr. Aqeel (Appliances)
[email protected]
GSM Service Center
Siddique Center LAHORE
SAJJAD/SARAJ
Tel: 042-578-9918-19
LAHORE MALL
SHAHZAD
Tel: 042-732-0894
SOURCE: I have Honda accord 1992
the s light flashing and no second gear means your tranmission computer needs replaced it is a common problem on 90 -93 accord
SOURCE: playing call of duty world
Dashboard or restart your system. That is a glitch that sometimes happens. It's nothing you did, but rather the Activision servers sorta messing up.
Who knows ? Who cares ?
