Can not get it to set properly for engine to start and run
Hey Dan,
this depends on what type of kill switch you have...
one type kills (breaks the hot wire) the connection and one type makes the connection to ground..(grounds it out).. try to bypass the kill switch to see if it will run..
Testimonial: "If I hold the kill switch "in" with my finger, the engine will start and run just fine. However, I can not determine how to put the "safety pull away" part so that it holds the switch in this "in" position. As soon as I let go with my finger, the button comes "out" and the engine stops just as intended with the kill switch. I look at another kill switch on a different boat, and it seems as though the "safety pull away" part holds the kill switch "out" and when you remove this piece, the kill switch goes "in" and kills the engine. Not sure if I am make sense. But it seems as though the two kill switches do not work in the same manner. ???"
You are missing the piece that holds it "out".. check with your local Mercury dealer
this is a little confusing...the local dealer can help,, I know,,no one wants to spend money there either..
I don't mind spending money. I was just trying you first. And, I need something to hold the switch "in" not "out". It is not my boat so I need to verify additional information but will continue to work on it. By passing the switch will work during the interim. Thank you for your help.
SOURCE: mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
SOURCE: motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
