Car Audio & Video Logo
E
EULALIO FRAUSTO Posted on Sep 11, 2017
NEED VOLUME KNOB FOR POWER ACOUSTIK PDN-626B - Power Acoustik Car Audio & Video
My power acoustik pd-620hb won't turn off
POWER/MUTE Button Press it to turn on the unit.Press and hold for 2 seconds to turn the unit off . Press the button briefly to Mute . Please note that the volume will be muted on all audio output connector.
1helpful
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
2answers
Lost power cord. What specs. i have output 9vac 1000mA. Is this ok
No, it's way too low power. Most probably you need 12V and something like 4-5A (4000-5000mA). The higher the current rating (Amps) the better, some reserve is always good to have; the unit will draw as much current as it needs, the rating means the maximum current that the power supply can deliver.
Good luck, and please come back with a rating/testimonial if helped :)
1helpful
I need an enclosure for a power acoustik mofo 12''.
Hello miles_jamike,
Power Acoustik recommends a 1.25 CuFt sealed and 2.0 CuFt ported enclosure for the P1, P2 and P3 subs. The PSQ needs 1.25 sealed and 1.75 ported. In physical size, this translates into about 16X12X14 for sealed and about 30X42X15 ported.
You should try to stay pretty close to the recommended enclosure volume for best performance. A good volume calculator is located here on the12V.com website. Just enter the proposed width, height, depth, and material thickness and click the "=" to get the CuFt.
If you are building (or having built) a custom enclosure for a specific location in your vehicle, all you need to do is stay very close to the volume recommended.
If you intend to purchase a generic enclosure, the Goldwood shown here at Parts Express is an exact fit. Atrend also makes good generic enclosures, their model 12SAL in a sealed box with 1.20 CuFt and the 12LSV ported with 2.50 CuFt would be good choices.
Crutchfield has both generic and custom enclosures made by JL, MTX, QLogic, and Bass Slammer. Crutchfield has excellent support. They will respond promptly and positively to your phone or email inquires. If you have never ordered from them, you can use a "friend referral code", such as mine, which is: p7sdj-hrx8q-9800g, and on any order of $200 or more, you receive a $20 discount. And I get a $20 credit on a future order. Also, many orders qualify for free shipping.
Hope this helps.
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
