Belkin wifi range extender extender N300
Your set may have a defective wi fi detection circuit that is causing all the grief. I had to return a laptop for this reason.
Maybe the signal is weak - try raising the router as high as possible off the floor and also try putting a deflector behind the router to direct the signals in the direction of tv set to maximize strength.
SOURCE: belkin wireless extender
how thick are the walls? what is the longest line of sight connection you can make?
SOURCE: I am trying to bridge a belkin n router to a d-link router
ok
the simplest way is to find some alternatives, here as some suggestions
now if you do want to attempt your solution do a few things first
first you do need to go into the belkin router's configuration page you can do this by:
or if you set up a password can't remember it do this first
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/F5D8231-4/p/312/r_id/166
now.. you need to find out if both routers support bridging.. you need to look into both router's configuration page, I couldnt find you router's manual and you did not posted you dlink router's configuration.
if you do find bridging try the directions found here
post back if you have questions after reviewing each router's configuration.
now an alternative option is to
SOURCE: Can I extend my internet range with a netgear & a Belkin router
DG834G is a modem/router, it is not a range extender that could extend the range of the wireless signal from the Belkin router.
