Video Game Consoles & Games Logo
Dru Higginbotham-Filter Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting my Wii to the internet
I have a new internet box with a new router code...it is saying "Error code 51330'
micky dee
Level 3:
  • The Master 3,015 Answers
  • Posted on Sep 14, 2017
micky dee
The Master
Level 3:
Answers
3015
Questions
0
Helped
1060311
Points
8762
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Oct 24, 2007
SOURCE: getting on the internet on the wii
Nintendo support page
That page has everything I would say only simpler. I recommend finding your router model here.
Follow the instructions and it will likely fix the problem... it did for me. If you would like, post your router model number and I or someone else will walk you through it.
Anonymous
  • 104 Answers
  • Posted on Jul 22, 2009
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
Anonymous
  • 52 Answers
  • Posted on Aug 30, 2009
SOURCE: wii code:51330
hold the power button in for 4sec or more to reset the last update. reconnect to your router and try to install the latest update. hope this helps. good luck..
Anonymous
  • 12 Answers
  • Posted on Nov 16, 2009
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
A
Anonymous
  • Posted on Apr 26, 2010
SOURCE: error code 51330
This error code usually indicates a problem relating to wireless security.
Trying to connect to the internet through Wii but getting error messgae # 51330
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings.
WEP AND WPA Security keys are case sensitive.
tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 • Nintendo Wii Console
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
3helpful
Error code 51330
The error code 51330 means that your Wii cannot connect to the internet through your wireless connection.
It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow so m
I am trying to watch a movie on net flix, however everytime I tried to look for the internet service the following error comes up: Error code 51330 is unable to connect to the internet.
Hi there!
Error code 51330 on the Wii means that the password you entered into the Wii to set up your internet was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct password/security key for your router. Please remember the security key is case sensitive.
Hope this helps!
1helpful
I received an error code, 51330 when attempting to go online with the WII console for the first time.
Hi there!
Error code 51330 on the Wii means that the security key you entered into the Wii to set up your internet connection was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct security key for your router. Please remember the security key is case sensitive.
Hope this helps!
I changed the ssid on my wireless router! I can connect everything but my wii! it is saying " Error code 51330 unable to connect to the internet. Choose internet settings and then confirm your connection....
Start your wii, go to the bottom of the screen and click on the wii icon.
Than go further in the program to internet conections.
clic on and your wii wil search for a new connection
My wii connect 24 won't connect to the internet and it say error code: 51330.
It's a problem with your internet connection. It could be as simple as mis-typing on of the settings, i.e. the SSID. Otherwise try changing this channel your router broadcasts on to 1 or 11. It worked for me. Check out http://www.nintendo.com/consumer/routers/en_na/routerIndex.jsp for more details about your router. Or http://www.wiierrorcodes.com/wii-error-51300-51399.php for more details on the error number.
Wii code:51330
try to double check and make sure you've inputted the correct type of password when setting up the internet connection for your wii.i've had the same error code before,and after changing my password setting to wpa-aes passphrase,ergo everything started working perfectly,my wii started connecting to my router and has been working fine ever since.
Top The Video Game Consoles & Games Experts
vince
Jun Salazar
Level 1 Expert
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
