Question about Razor MX350 DIRT ROCKET - BLUE
Razor MX350 how to reattach kickstand spring
MX350 has spring detached from kickstand. How to re-attach?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Razor Master
  • 55,893 Answers
Hi, Jerry for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Tips for changing kickstand spring Harley Davidson Forums
Removing and Replacing Kick Stand Springs
http://www.marathonandmore.com/mini-moto-dirt-bike-service-manual.pdf
Razor MX350 Dirt Rocket Parts
Razor Dirt Rocket MX350 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Posted on Sep 11, 2017
4 Suggested Answers
SOURCE:
sisadsl
  • 1508 Answers
SOURCE: Benelli scooter-
there should be a small pin with a knob on it near the stand pivot bolt, it may have broken off and might need welding
Posted on Apr 04, 2010
Testimonial: "I found the post but it's attaching to he bike that I seem to be hitting a wall on... thoughts?"
  • 14585 Answers
SOURCE: Spring on wiper arm became detached. How do you
There is a little arm on the wiper that the spring goes on if it missing you need a new arm. if it still ther you can get it on with needle nose pliers. you will have to take the arm off good luck
Posted on Jun 18, 2010
  • 743 Answers
SOURCE: Do I need a special
There are tools for hooking and stretching a spring but, if you can grab it with some vice grips, have the kick up where the spring stretch would be the least, you should be able to get the spring on.
Posted on Sep 02, 2011
Can i use brake spring pliers to replace the kickstand spring
Remove the pivot bolt in the kick stand, put the spring on the kickstand and then pull the kickstand into place and get someone to push the pivot bolt back into place.
Aug 12, 2015 | Motorcycles
My kick stand fell off while riding. Not sure of all that was lost or how it goes back on. Any suggestions?
Hi Steve, Well hopefully not much, look underneath frame and see whats left, here is a complete list of parts. Anchor plate held to the frame by a bolt that screws into a threded spacer, a solid pin, cotter pin and washer . Then there is the kickstand and its bumper witch is held in place by a bolt, a catch, and a pivot block. A kickstand spring that attaches to the anchor plate at one end the other end goes to the kickstand. Good luck
Mar 25, 2015 | 2007 Harley Davidson FXDC Dyna Super Glide...
How to change kickstand spring
this depends on design of side stand - usually the easiest way is to remove the side stand pivot bolt remove side stand from channel., attach spring to both ends. pull side stand into pivot hole and reinstall bolt. there is less tension and easier to install if you orient side stand in retracted position..
Jan 08, 2015 | Motorcycles
Torro Lawn Mower side discharge spring
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Jul 08, 2013 | Garden
Attaching kickstand spring
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Kick Stand Spring Fix My Hog
Oct 30, 2012 | 2007 Harley Davidson FLHT Electra Glide...
Where does kickstand spring attach on 2010 street glide
Apr 29, 2012 | 2006 Harley Davidson FLHR Road king
How do you replace the kickstand spring on a 2000 Harley FLHTCUI?
Have a friend hold bike up for you with the kickstand in,attach spring to kicks stand, and with a pair of needlenose pliers stretch the spring to attach to the loop on the frame
Dec 04, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Do I need a special tool to attach the kickstand spring?
Sep 02, 2011 | Harley Davidson XL Sportster 883...
How to attach kick stand spring on 2006 road glide
Take the bolt out of the kickstand, attach the spring, then use the kick stand for leverage to stretch the spring, and re-install the bolt...
Apr 10, 2010 | 2006 Harley Davidson FLHR Road king
How to put spring back on kickstand 2004 1200 sportster
There is a place on the frame and a place on the kickstand for each end of the spring to connect to. With the bike on the kickstand and someone to help steady the bike, use a pair of side cut pliers or a very strong spring hook to pull the spring and rconnect it to the kickstand.
If you can't get it this way, remove the pivot bolt, connect both ends in their proper positions and work the kickstand back into position so the pivot bolt will go back in.
It's tough but it can be done.
Sep 24, 2009 | 2004 Harley Davidson XL 1200 C Sportster...
Razor MX350 DIRT ROCKET - BLUE Logo
299 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
