Heating & Cooling Logo
Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
MY FRIGIDAIR MODEL FAA086P7A 8000BTU AIR UNIT WAS TAKEN OUT OF STOREAGE THIS YEAR. WORKED FINE LAST YEAR,TRIED RESTET BUTTON ON CORD,SEEM'S TO WORK,STILL WON'T POWER UP, TRIED REMOTE STLL WON'T WORK, DOES'NT SEEM TO BE GETTING ANY POWER TO UNIT.
Anonymous
Level 3:
  • Master 534 Answers
  • Posted on Jul 28, 2009
Anonymous
Master
Level 3:
Answers
534
Questions
0
Helped
147850
Points
1546
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
1helpful
May tag window air conditioner 8000BTU #M6X08F2A. Water blowing out A/C vents. I have 2 and both do this. Thanks so much
Hello Ron,
The water is from condensation.
  • These units have to have a pitch. Your units are mounted too straight (90 degrees), the pitch or inclination is supposed to be around 2 to 3 degrees outward ( toward the back of the unit)
  • And also there may be a rubber plug on the bottom of the AC for drainage.It has to be taken out.
Maytag Air Conditioner Installation Instructions
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
4helpful
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
1helpful
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
I have a model # faa065p7a A/C The power cord burned out with some sparks by the test and reset part. Called frigidaire and they said you could not replace the power cord and had to buy a new unit. This...
Hello, i have replaced cords on many window units so yes you can replace the cord. I believe if you go to a online appiliance website they will have the cord you need. I have found this website online with frigidaire parts http://www.repairclinic.com/Shop-For-Parts?s=t-faa065P7a-==
Hi, my Frigidaire AC (FAA068P7A) unit was working fine last year. Put it back in the window today and now it won't power on. I checked the power cord, but cord is fine (I actually opened up the machine...
Sounds like a breaker has tripped (caused by the unit) or is it might just be 'off' for some reason. I would check the outlet (where the AC plugs in at).
If the AC is a 110V unit you can check the outlet by plugging in something else, i.e. a hairdryer. If the hairdryer doesn't work either - then you know your breaker is tripped. On the other hand if the hairdryer 'works' then you know the problem is in the unit, where I'm afraid you'd be better off to have a technician to trouble-shoot it, although you could try sending additional information at this point for more help.
Remember if it is a breaker tripped - it was probably tripped by a malfunctioning Air Conditioner so if it 'trips' again in the immediate future you will need someone to check it out.
good luck!
Fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
1helpful
Window unit will not power up
You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
Unit stops working and I need to unplug unit
After 7 years of great service you should retire this system and replace it with a new unit.
Products made these days are not built for quality, that was back in the good old days, it's 2008, things are made to only last a short period of time.
Sorry I couldn't be more help, but I will only tell you the best solution for your problem and not waste your time running around trying to fix something that may cost you more than replacing the problem you already have.
Have a Great Day!!
Glenn
Wont blow air
Sounds like the blower motor or capacitor has failed. Either part should be checked and replaced by a licensed contractor.
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
