SOURCE: Error 99 message keeps popping up
Hi
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
see http://www.mcvr.com/canon_digital_rebel.htm?gclid=CJqG4cvc05oCFRMhnAodCHUA3Q#shutter
ERR99 (error 99) is an indication that there is a
communication problem in the camera. It is most often an
indication that the shutter needs to be replaced, but it can be the
result of other problems. All digital cameras occasionally
need to have the shutters replaced. In the days of film
cameras, it was rare to wear out a shutter because the cost of film and
developing limited the number of times the shutter was cycled.
With all those ones and zeros being considered "free" in
digital cameras, it is not uncommon to take several hundred or more
photos in a day. Even with a live-expectancy of 50.000 to
100,000 cycles, the shutters in digital cameras do reach the end of
their life and need to be replaced.
Shutter
replacement (usually associated with error code "99"):
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It
came time to part with my review unit of the G1 (Thanks T-Mobile!) and
send the phone back to its rightful owner. But what about all the
personal info on the phone? The apps, texts, e-mails, AIMs and all that
jazz? A quick search of AndroidForums.com turned up an easy way of
restoring your G1 to factory settings:
if you power
off your phone and hold the home (shaped like a house) and the end (red
hangup button) for about 20 seconds you get a triangle with an
exclamation point and a picture of the G1.
Now all
you have to do is pop open that pretty QWERTY keyboard and there are
several keyboard shortcuts you can use to accomplish what you want to
do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory
settings. I'm sure the soft reboot could be helpful too, should you run
into problems a troubled application may have caused. We didn't try the
other 2 options so use at your own risk.
By the way, I couldn't
live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile
service plan. I'm still a loyal Verizon customer and will simply have to
keep both plans... but I NEEDED the G1. So basically, you can expect the
application reviews and insight you've gotten at phandroid.com to
cotinue since we've got our very own device now!
[Via Android Forums]
SOURCE: Error E10 keeps popping up and washer stops 2 or 3
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
