SOURCE: Drier will not start
Check and make sure that the door is secure. If the door is not securely shut and latched it will not turn on. You could have a problem with the door switch though too. It may need to be replaced. If it is not sensing that the door is latched anymore the dryer will not come on. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad that I could help.
SOURCE: hp pavilion dv9000 bleeps on start up
This error code is almost always a blown video chip. You can try reseating the memory or using only one stick. (if you have two), but chances are that your video is blown.
SOURCE: My Lacie Rikiki 500GB works
I have the same problem with my powerbook G4!!
do you allready haver a solution? i think the power is just not enough!
SOURCE: pc doesn't start after initial (but double !!) bleep
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
here are the beeping explaned
two beeps,means bad memory.
