SOURCE: communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: service manual for gm338
http://www.motorola.com/governmentandenterprise/contentdir/zh_CN/Files/ProductInformation/GM338_Aus.pdf
SOURCE: What's the range of GM338 motorola base radio?
i have a similar set and i get abot 20 maybe on good days 22 miles hope that helps
SOURCE: In motorola gm338 vhf radio, if programme
GENERAL SPECIFICATION Low Band (GM338 only) = 29.7-36MHz / 36-42MHz / 42-50MHz If you need more help come back.Post /
thumbs / testimonial are
welcome!
UHF
403-470MHz
450-527MHz (1-25W)
450-520MHz (25-40W)
VHF
136-174MHz
So if you do 160-500 it will not generates the LOW BAND capacity because the Channel Spacing = 12.5/20/30kHz 12.5/20/25 kHz.
welcome!
