If your netflix is still showing an empty or black box..then simply delete it if allowed and download it again...it is possible it has lost the drivers for this particular setting and will re-establish when downloaded..good luck
Likely the Netflix app just got stuck. I would turn off the tv, disconnect it from power for about 15 min to be sure all power drained and then plug it back in, launch the app and see if it's working.
1. Check your input and make sure you are on the right one.
2. Check your internet connection.
3.Check to make sure your TV doesn't have to be on a certain channel. Some are like the TV's of old and have to be on a certain channel.
4. Check your connections. ALL wires plugging into TV at both ends---the TV and whereever else they are plugged.
5. Check your TV for updates.
6. Make sure you don't have TV parental controls on.
7. Go to Netflix on a computer/phone, and make sure all is good with their site/ your account is good/ no parental controls on.
That';s all I can think of. Hope this helps, I believe one of them should do the trick.
Good luck
Paul
Often Smart TV apps will not tell you there is a new update- they will just fail to work.
I would delete then reinstall before resetting the tv to it's defaults. That usually works.
Sometimes it is on the server's end (Netflix's fault). Remember many of the apps will upload data from their companies before loading, sometimes you just need to be patient because the server is down on their side. Simply just waiting a few hours or a day or so will have it working again- try contacting Netflix customer care and ask them if it's a known issue before driving yourself crazy with futile solutions.
It probably runs ANDROID OS like your phone (unless you have an iPhone) Usually prolonged pressing of the OFF/ON control will reload the operating system. Remember these "smart TVs" are only big computers running Android OS in one box. It MUST be connected to your internet router either by Wi-Fi or cable. If it still don't work - send it back or call the service guy from where you bought it and remember the Hisense is a cheapo china made thing
Why dont you try to reset your TV, remember that is a smart TV, for resetting, refer to book or contact your supplier/dealer
Posibly your tv is not connected to net. check in the network setting if it is connected or not
SOURCE: black area on screen,
Hi omsoc,
This could possibly be an issue with closed captioning. While some closed captioning is a marquee-type text near an edge of the display, your television may have an option turned on to display a different channel of captioning that would likely display a large black box on your screen if there is no data to display. This would explain why this would take place suddenly at the same time each night, as well as why pressing the display button would cause it to disappear. I suggest you look into your menu to try turning this option off, then watch the channel you normally watch at this time. If this does not resolve the situation, I recommend you contact your manufacturer’s product support line.
Thank you,
Jason,
Go Ahead. Use Us.
SOURCE: TI 86- Texas instrument
OMG THANK YOU SOOO SOOO MUCH
i had borred my friends ti-86 and when school finished i forgot to return it. i ended up leaving the calculator in my car where the sun fried the battery.
3 months later i brought new batteries and when it turned on i only saw black and i started to freak out thinking i had to buy a new one..
ONCE again thanks for the solution
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
SOURCE: Describe your hisense tv ~20in(?) Flat Panel TV. I
I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
SOURCE: LCD Screen replacement for KDL-55HX800 55in 1080p 240Hz 3D LED TV?
Hi there and good morning to you
I am sorry I do not know of anyone apart from trying AMAZON.
Here in Iceland Imight eventually find one but it is far away.
Good luck toyou
Kolbrun
