I'm not an NE guru but I work on many others.
You really need an administrator for the Voicemail to reset the password.
Try this.
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code (0327).
Good luck.
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
SOURCE: nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
SOURCE: toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
