Need to know where to buy
SOURCE: it appears that i have oil dripping from my oil
oil leaking anywhere on the engine runs down and gets caught on the oil pan lip, builds up runs over and then looks to be an oil pan leak. so what you do is take the thing to a shop with a lift, like an oil change or muffler shop, and ask them to put it up on the lift so the rest of the engine can be easily examined for leaks. if there is no other place above the oil pan with a thin layer of oil on it, then most likely the pan gasket is leaking. before you buy the gasket take a good look at any suspension hardware which could obstruct easy removal of the oil pan. it may require lifting the engine up out of its mounts to get the gasket replaced, so simply snugging up the bolts holding the pan on and living with a small leak may be the way to go.
Testimonial: "thank you very much. i will do that. have a nice day and i am glad this site exists and will use it again..."
SOURCE: Replace oil pan
Either jack up the motor or jack up the car and let the suspension relax that should help
