SOURCE: I need a belt diagram for a Landpride 6' finish mower.
Check out their website and look under manuals. http://www.landpride.com/main_products/main_gm.html
If you don't find it there, I'm sure customer service could hook you up...
SOURCE: need diagram for serpertine belt
This is for the RM59
http://www.woodsequipment.com/workarea/DownloadAsset.aspx?id=18306
Belt routing is on page 11 Figure 6.
Good luck.... lots of twists in this belt to properly install it.
If i missed the intent of your question please repsond so I can get the correct diagram.
Thanks for choosing FixYa,
Kelly
SOURCE: I'm trying to locate a users manual for a Woods Zero Turn mower model 2560 yr 2000
Go to their website, the owners manual is there
http://www.woodsequipment.com/files/Products/Manuals/MAN0875.pdf
SOURCE: How to replace belt on woods rm660 finish mower
not sure about the 660 for sure but normally the woods mowers have a tensioning wheel that keep the belt tight when it is running and if you depress the wheel it should allow you to remove the old belt and put on the new one. Take a look and see if one of you pulleys has a spring attached to it and if so that is the tensioning wheel.
