SOURCE: Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
SOURCE: LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
SOURCE: Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working
abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
SOURCE: my LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Testimonial: "well done"
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
OE in your LG dishwasher is a drain error and dishwasher not draining issue usually occurs due to
kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for
any visible clogging, remove if present. If no visible lint is present then
remove then turn off the dishwasher and remove the drain hose and check for any
visible clogging. If it's still not visible then the drain filter or drain pump
is clogged and you'll need to clean the drain filter and drain pump. Also,
check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further
assistance.
Daniel
Hi
Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller.
Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat.
Hope this helps...
Please post back for any further assistance.
Daniel
