Please let me know ASAP
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button. The safe opened. The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe. Wrong! Do it my way should this problem happen to you.
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
SOURCE: I have a Hardline Electronic
well -- if you have lost the key, you can take the serial number of the safe into any loccksmith shop and they will be able to call the safe company and get the key code and cut you a new key.
also -- look on the front of the lock cylinder itself and see if there are any numbers imprinted on the lock and with those numbers the locksmith might also be able to look up the key code and cut the key. the cost of this will be around 15 dollars.
c...
SOURCE: kingavon electronic safe 28
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
