SOURCE: squeaky elec. dryer
This could be attributal to a rear drum roller lacking proper lubrication, or having been overheated. Also, a dry idler pulley bearing could cause this chirping. Don't allow this problem to continue without investigating the cause.
SOURCE: Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
SOURCE: chirping on acceleration
it could be belt noise or pulley noise try belt dressing it could also be several other things p/steering pump alternator a/c compressor or pulley is your a/c engaged when it chirps if not it might be the clutch on the a/c pump
SOURCE: maytag electric dryer, lights flash, chirping
I had this happen with a maytag washing machine. The repair guy replaced a board and it worked fine. I'm afraid that's what happened here.
