Then it will quit lifting period but if I lift the handle and let it set for 4 to 6 minutes it will began to creep up in fast jerking motions. After I drop the lift it will not lift for another 4 to 6 minutes.
If you want to solve your problem, click on the link I attach
Ford Tractor 1120 1220 1320 1520 1720 1920 2120 Service Repair Workshop...
SOURCE: Lift Glass opens sporadically
Give latch mechanism a good spray with white lithium grease or similar also, in case latch is sticking slightly.
SOURCE: Can't lift handle for my foot presser
Take the machine apart to the point where you can see the pivot point for the presser bar lifter and spray WD40. Let sit for a few hours and try again. Repeat until the presser bar lifter releases.
Sewing Machine Parts
SOURCE: '07 5403 John Deere Tractor lift arm will not lower
some-times the 3pt linkage can go past the top position.
When this happens - you will need to force! the linkage arms down.
SOURCE: Ford 2n tractor. Engine turns, but very slowly. Is
you can get a replacement for that starter at most auto parts stores. there is nothing on the N series tractors you can't buy on line, even complete engine rebuild kits and fenders. look for antique tractor parts suppliers. is it a 6 volt or converted to 12 volt?
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
