Question about Pride Mobility Products Pride Victory 10 - Three Wheel
Pride Victory 10 - Three Wheel wiring diagram
3 Suggested Answers
SOURCE:
  • 61 Answers
SOURCE: pride victory 10 clicks while going foward
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Posted on Mar 23, 2010
rgall3285
  • 63373 Answers
SOURCE: What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
check the owners or operating manual.
Posted on Jul 12, 2014
Wiring diagram for a victory pride 9
Hi I found this type in .google search....,victory 9 wiring diagram ..good luck
May 25, 2016 | Pride Mobility Products Victory 9 Scooter...
Turn on. Won't go. Six beeps. What's wrong?
hi ring pride 1-800-800-8586 about youre problem It could b a fault with youre control box ......good luck
Nov 29, 2015 | Pride Mobility Products Pride Victory 10 -...
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
I need a wiring diagram for m Pride victory mobility scooter. Where can I get one?
hi sadly you won't however i can help , what's the problem ?
Regards
Rob
www.gewizrepairs.co.uk
Jul 09, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
I need a wiring diagram for my Pride victory 3 wheel scooter. Where can I get one mine is all messed up?
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
Victory scooter will just click when I push in switch and not move if I take seat off and jiggle connection at the big harness it will go
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Regards
Oct 26, 2013 | Pride Mobility Products Pride Victory 10 -...
Battery charger not working. A white wire that connects to the AC plug has become disconnected. Can soldering it back on work okay?
yes this is a common problem on a victory scooter i know i have one and the same problem just solder it up carefully
May 02, 2010 | Pride Mobility Products Pride Victory 10 -...
Pride victory 10 clicks while going foward
Mar 22, 2010 | Pride Mobility Products Pride Victory 10 -...
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
88 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
