Did not find any S# beginning with 'X'. Did find this and the link is below. Seems to indicate your 16ga was made between 1903 and 1939. Interesting reading.
*Identify pre-WWII Sweet 16s: As stated in the introduction, pre-WWII Sweet 16's did not have engraved serial numbers. Instead, they were simply numbered. Guns engraved with the "Serial Number" of 1 to 228,000 were made from 1903 through 1939. Since the Sweet 16 was introduced to the public in 1937, you'll only be able to guess that your gun was manufactured in 1937, 1938 or 1939.
http://goneoutdoors.com/out-browning-sweet-16-manufactured-8592078.html
SOURCE: what year was my fox sterlingworth 12 gauge
Go to nra.org and do a search.Or go to gunsamerica .com and get into a shotgun chat forum... hope this helps you.
SOURCE: my model 88 Harrington and Richardson 12 gauge
You first need to **** the gun then remove the fore end and barrel and look at the breech face when pulling trigger , you will see if firing pin is there. If not u need a new pin as it is probably broken. Take it to gunsmith if u are not familiar with the workings and get a new pin .
SOURCE: I have an old H&R1871 Topper shotgun patened in feb
Yes you can, those old shotguns were pretty much all the same, a lot of the parts interchange, but go to gunparts.com, they have everything there, if not, find Jackfirst, He has a ton of stuff. I have the same gun right here that was my fathers, bought in 1913 for $13, almost 100 years old!!!
