SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
[email protected]
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
SOURCE: cajun electric smoker code ErrF. Was working but
Possibly a control unit malfunction.
First try a full reset. Turn off and unplug the smoker from the outlet. Wait a minute or 2 to allow the controller to power down completely. Plug the smoker back in and turn on.
If you get the same error message it is likely that the control unit needs to be replaced. Part #990050048.
You can contact Masterbuilt directly at 1-800-489-1581
SOURCE: where can i buy a
The following two places carry Masterbuilt parts.
www.appliancefactoryparts.com
http://www.searspartsdirect.com/partsdirect
